How much time do I have on these bearings?
bmcreider
Got Secondaries?
Fort Worth, TX
Ok so I've had 2 SHOs go under because of rod bearings, I don't want a third.
Thing is, the 92 I have now has every record of every oil change...which is Mobil 1 5W-30 Synthetic every 2,500 - 3,000 miles...and it's never ran low on oil.
But, it has 180k miles on it...and I can notice a slight knock for half a second upon cold-*** start up.
Is it just the valvetrain noise, or are my bearings beginning to fade?
gbizzle27
Bradford, Pa
You have already had 2 cars fail because of rod bearings? That should tell u to change them asap, there shouldn't even be a question. It only takes about a day and 100 bucks. With that knock, change them.
wood_e
The dude
Ames, IA
Yeah just do them and get it over with. Also post pics of the engine internals with that mobil one in there.
I KNOW I need to do my bearings and with SHOWYA's failure I'm making that a priority on my car.
About the noise: Get a mechanics stethescope, you can easily pinpoint odd noises with one
bmcreider
Got Secondaries?
Fort Worth, TX
Ya I know what you mean, the bean had less than 140k on the clock and here's what it looked like when I took it apart:
Badcranksmall
Badbearing
I was going to put this off until NEXT payday...but I'm going to go ahead and do it now. $67 now and not a lot of lunch for the next week or so is better than a new car later.
greenbeanmtx
King Skidmark
Waco Tx
I need to do this to the 89 too. Never been done. I guess i should start making the to do list..... sigh.
SonicRiot
Handbanana!
CT
DHMag said:
all cars with over 75K miles, not just the SHO, will have cold startup knock.
109K miles on my Plus, never heard a knock on startup.
SeanMc
NoMoSHO
Can you do them now? :rofl:
yozsi
SF Bay Area
hmm, thats bull. my volvo has 360,*** on it and it makes no knock on start up, even when i had it sitting for over 6 months. my 240z has 260,*** on it, and no knock either.
gurucomputers
Everett, WA
94 SHO ATX here with 210k. No knock great oil psi, "BUT" after what all i've seen here with sho's having less than 150k I am making it a priority as well. $75 is chump change compared to a total rebuild.
LiLGhettoSmurf
Owego, NY
I think this might be my problem too, there is no way I can do the bearings myself, how much do you think it will run if I take it to a shop?
SHOtimer
#2910
Santa Clarita, Ca
Most shops will laugh at you, and or refuse.
Doug
DHMag
Free At Last
InCahoots, Texas
regardless if you hear it or not, ALL engines will exhibit cold start up knocking as mileage is increased.
AREA 91
PA SHO SHOP
Area 91
Too bad you don't live in PA. I'd do those rod bearings for you! Whatever it takes to keep SHO's on the road. :thumb:
SHOWYA
TurboSHO Member
Houston, TX
I have rod bearing problem. I need a 3.2 block(complete - rods, pistons, crank) ... anybody?
maybe 3.2 rods and pistons?
Rockledge
Pluggin' away
Connecticut
Here's what I'd do if I were you. Print copies of the rod bearing tutorials (K Metros, SHOPP) and pick up the bearing kit at RCM auto (includes gaskets and bearings). Then go to a local shop with a good reputation and tell them that you had intended to do the job yourself but just don't have the time right now. Show them the tutorials and parts and explain to them that most SHO owners do the job themselves, that there is no need to remove the engine or do anything dramatic like that. Try and give the shop the impression that it's not that difficult a job (because it's not) so that they don't get big dollar signs in their eyes or reject the job outright thinking it's a huge project.
