drdave
This is actually a two-part question.
My 90 has a retrofit sticker in it that was done in 98. It said they used 2.1lb of refrigerant and 8oz of lubricant. I'm guessing that is around 32 - 33.6oz of refrigerant.
My high-pressure valve was leaking so I had it serviced. They said they only pulled 10oz of refrigerant and charged me for an additional pound. That only amounts to 26oz of refrigerant in my book.
What is the correct amount of 134a for my 90?
Second question;
Before the ac service, my ac clutch would cycle every 30-45 seconds when first started, but would stay engaged all of the time when at operating temperature. Now it doesn't cycle at all, just stays engaged all the time. I am told not to worry about this, that 134a acts differently than the r12 did. But I know this is not right.
Can the cycling switch be replaced without removing the refrigerant? How should the clutch act with too much or too little refrigerant?
Too many questions, way too little time (and money)!
<small>[ July 07, 2002, 01:55 AM: Message edited by: drdave ]</small>
Second question;
