How many LPH is the tank pump?
M1T
Auburn,NY
I was curious how many lph the tank pump is and if it's a standard high pressure high flow fuel injection pump or if it's low pressure high flow. I've heard of guys using the severe duty hpfp and having to use a kb boost-a-pump on the tank pump to keep up with the hpfp under the hood. Why not just change the tank pump out for a bigger pump?
StealBlueSho
NA
There isn’t one available from what I understand...
I think there are options for the F150, but not transverse setups. One option is to add a second pump, but I don't know how easy that would be.
M1T
Auburn,NY
Yeah, you can always add an inline booster pump but it's always easier to jack the voltage up on the stock pump to get more flow. I understand now why they add a boost-a-pump. Thanks for the info!
Lostneye
NY
Look into the stock pump for the 2019 Navigator with the 3.5L they have a higher volume pump than the fords.
Other EB pumps may not be a direct swap but might possibly work. When I had my Lincoln Mark VIII there was another Ford pump that needed the connector rewired(the positive and negative were reversed) otherwise swapped right in.
