How it is possible to improve a transmission?
Rubix
Maintenance, tranny cooler, shift kit, tune/chip.
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
Step one: remove AX4N.
Step two: get MTX and install drain plug in the bottom
Step three: sell your extra kidney for a Quaife or wavetrac
Step Four: install Quaife into MTX
Step five: Install MTX.
forgot a couple steps but I fixed it for ya
another good way is to give it to Nik97, if it lasts 5 good hard passes that transaxle is bulletproof.
96blackSHO
Wrentham, MA
step one: blow up 6 automatics under warranty,
step two: remove AX4N
step three: install MTX
Step Four: blow diff pin on race track
step 4 run out of money for quaife or wavetrac
follow those four steps about you could be just like me!!!
kikkinasphalt
Wrrrrrrrr
Missouri
Step two: Install MTX.
no no no no
1) remove factory junk.
2) rob banks
3) profit
4)
bacernate
97 MONEY PIT
Denver, Colorado
The tuner was the best thing I ever did to mine. 2 years gone by with a tcc problem being held together with Pauls tune. Cooler a plus and remove 5/16 steel lines and install 3/8 fittings and rubber hose. Also installed Schaffer's synthetic fluid and temps dropped 50 degrees in July.
96blackSHO
Wrentham, MA
i couldnt tell if mine got better or worse with my tune i had shift kit after market cooler and tuner and i still went through them like toilet paper
venom
Rowboat Design
Toledo, OH
You guys have it all wrong...
Wrong MTX that is :munch::munch:
Only that weak POS diff in the MTX-IV is the worry.
But the best upgrade for the ATX is removing it that is for sure.
AREA 91
PA SHO SHOP
Area 91
Step one pick up your diff pin and hand it to you for a key chain.
J/K
In all seriousness, the single biggest "mod" for an automatic tranny is to keep that fluid cool!!! A big cooler and possibly a fas as well.
96blackSHO
Wrentham, MA
J/K
haha and you did do that, kirk still hasnt made it for me yet
Gen 2 SHO ATX cooler is a perfect fit and will do the job quite well.
tinkerkathleen
