How is oil consumption on your SHO?
Jeff2017
Just wondering if using no oil between oil changes is the norm for the SHO. I have 11k on my 2015 and it doesn't use any oil that is noticeable on the dipstick . I follow 5k mile intervals using Mobile-1 5w-30 synthetic. Not sure what was in there for the 1st 5k. Hopefully this continues to be the case.
xFallenxCripplex
Yea I have not seen any oil usage except when I had cylinder 4 and 6 rod bearing failure I was half quart low with 13k miles on the motor
So not too far away from my third oil change
Sent from my Pixel 2 XL using Tapatalk
ridered74
My 2011 had 169K on it when I sold it, did not use any noticeable amount of oil between changes.
6500rpm
2013 w/ 60k miles and oil use is minimal as in it doesn't show on the stick and I mark my oil bottles (5qt+1qt) and I get less than 1/4" difference between what I put in and what I get out. Change cycle is 5-6,000 mi w/ Royal Purple. Blackstone oil report came back perfect w/ an o.k to go 8,500 mile intervals if I wanted to. They did indicate that the viscosity was a tad thin for 5w-30.
shaker281
USA
111,000 miles and I use QS Ultimate Durability and go 6000 miles between changes. Always reads full.
Johnbigdog
michigain
2016 perf. Pack changed every 5K or so with motorcraft full synthetic. 67K on the clock. No smell of fuel in the oil like when running semi synthetic. Use maybe 1/2 quart starting recently.
Auggie
Maple Grove, MN
2015 SHO with 3600 miles and I use Penn 5W30 conventional oil and it shows always full on the stick .
bmytych
