How hard to replace freeze plugs?
mph1001
Los Lunas, NM
I've got a wrecked 94 ATX that appears to need freeze plugs. It starts and runs smooth but when I tried putting water in the radiator it poured out between the oil pan and the trans. Not where the trans bolts to the motor but the section that goes towards the passenger side, so I guess that's the right bank of the motor. Is it possible to replace them without pulling the motor and trans? It didn't look like it to me. Thanks, David.
sperold
Last to Know
Usually, frost plugs only come out when water freezes in the block. And that can be tricky, as sometimes the block suffers.
Frost plugs are difficult to install even with the engine out on a stand. They have to be started square in the block and pounded in with a hammer hitting it square on.
Do a little research and find out if any frost plugs can be replaced with a block heater, as it will be a lot easier than trying to pound in a frost plug. Only certain locations will accept the freeze plug due to the proximity of the cylinder wall, but if you got them cheap enough, you could remove the heating element which is what hits the cylinder wall.
Get a mirror back there with good lighting and see how many plugs you need, and look for anything that looks like a crack between the plug holes. Even if it cracked, it can be repaired if you are willing to take the engine out.
Have a good look at removing the y-pipe and lowering the subframe enough to get in there to take a whack at the plugs. You may have to remove the subframe and support the engine from the top, which makes it risky if you are the guy under there, so have a redundant support system in place as well.
Good luck.
mph1001
Los Lunas, NM
Thanks! I am hoping the block isn't cracked. I'm gonna try to get a better look again, maybe even borrow an inspection camera to try to see where it's coming from.
TimboSHO
Intermediate
Wyoming, MI
I bought a SHO that the freeze plugs rusted out due to the rotten brown antifreeze that was in it. I replaced them all (had to pull the trans to do the ones on the back of the block, and pulled the timing belt to do the ones on the front). Then I had other engine problems likely due to it being overheated before I owned it. Finally junked the motor and built a 3.2.
