How fast does the SHO engine rev?
caleb690
I just got a 94 SHO mtx with 99k miles. When I am at idle and push the accelerator it will hesitate before it revs. Also, when I am driving in 2nd or 3rd gear at normal rpms and floor it, it slowly climbs till I get to about 5000 rpms then it accelerates nicely. Iv'e never drove another SHO before, but it seems like its lacking the low end torque it should have. Is this characteristic of all SHO's or is something restricting my engine.Thanks.
philw349
PhilW
Tucson, AZ
It could be a bad throttle position sensor. I replaced mine for a problem with thumpy shifting, because when it acts up it makes dead spots in the accelerator (possibly at the beginning in your case) and after replacing it I felt bit more low end pull. At 3950 (~4000) rpms the second stage of the intake open up on SHO's and the car pulls a lot harder so that's typical, but you could be having a problem with the low end. I'm sure others will have some good advice too.
noSHO
ohio is for hustlers
That's pretty normal, what you described about not having a ton of low end power. The yamaha engine is a high revving engine, and makes better power up top. If you do that in ANY standard transmission at "normal rpms" car really you will get that sort of "lack of power" feeling. The engine can't downshift like in an automatic to a better suited rev band, and you are putting too much of a load on the engine. The engine cannot burn the amount of fuel you are asking it to with the amount of air it is getting. The engine likes revving, don't be afraid to take it up there.
-Dave
green/black 92, mods
8359139 68b0 00C8006C
philw349
PhilW
Tucson, AZ
Yeah the low end will always be much slower than the top end. As far as the hesitation when hitting the gas pedal in idle (do you mean neutral?), that could be a TPS or something else.
1fastsho
Athens Ga
*might* be plug wires and plugs........
Shawn Pasley
Innovative Performance Technologies
770-725-4631
www.iptech.tv
92 SHO red/grey
3.2L(bored) Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm FRONT sway bar, 28mm REAR sway bar,rear strut tower brace, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 Toyo Proxes T1-S's on TSW VX-1's. 15 lbs of boost here I come!
SHO_of_SD
Sioux Falls, SD, USA
Take a look at the MAF. It may need a cleaning. A dirty MAF will slow down the reaction time of the sensor causing poor throttle response. A bit of electrical cleaner and a careful hand with a toothpic can clean them up nicely. Good Luck
