How do i put a new deck in my 89 sho
SHOnoFEAR
Josh
Hickory Corners, MI
i dont know if i should rewire all the speakers and bypass the amp or what i should do if someone can help that would be awesome. the soundsystem is the stock jbl and i want to put an older sony cdplayer in it. if anyone can help thanks
Griswold,CT.
when you pull out your deck you will unplug a harness that plugs into the deck, go to a electronics store, maybe best buy( i bought mine at tweeter) and get the harness that plugs into that connection, all you would have to do is take the wires to your new deck and splice them into the new harness wires, then just connect the harness you bought into the harness that is in your car
jmpSHO
Massachusetts
I think you need to bypass the amp in order to get an aftermarket radio to work, I may be wrong though. Either way they sell a bypass plug but it may be a little difficult to find one.
SHOnoFEAR
Josh
Hickory Corners, MI
ok thanks so one last time i get the bypass for the amp and then just get the plug for the harness behind the stereo and wire the deck and im done?
Griswold,CT.
just for the record, i didnt have to by pass anything and i used two different aftermarket head units, by buying that harness you shouldnt have to by pass anything, I could be wrong on that statement, but like i said both my aftermarket head units worked so i never even thought of it
