Is the sound coincident with the tire rotation or the steering wheel being turned? If it is with the tire, you may have worn bearings allowing the tire to change axis, but I'll bet you are talking about a loud scrunching noise as you turn the steering wheel. That would most likely be the upper spring pad from the left front strut (by your description) that is rubbing against the inside of the strut tower. The colder weather brings this out because it makes the rubber less pliable. The solution is to get some silicone grease (Sil-Glyde) between the rubber pad and the metal tower. I turn the wheels to each side to allow me to reach up in there with a rubber gloved hand with the silicone grease on a fingertip.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
