High End Hesitation
Where all good SHO's go when they die
My SHO is putting out about a third less the power between 5500 and 7000 rpms than another stock SHO I have driven a bit over the weekend. I have been sensing this for a while but it was confimed after driving my friends 89. Secondaries are opening fine. Any suggestions?
60K has not been done since the engine has been in possession of me or my someone i know . Probably 20,000 miles. Plugs and wires a few thousand ago. When I pop the hood i smell gas- How do I check fuel pressure? i guess I can find that out myself. thanks.
masho95
got Zex?
Chicopee, MA
Fuel pressure can be checked with a fuel pressure gauge hooked up to the schraeder valve on top of the fuel rails. The smell of gas could be...
http://www.shotimes.com/php-bin/mod...le=article&mode=thread&order=0&thold=0&sid=52
Redline
Fire It Up
Sandpoint
Clean your MAF if you havn't done so already. It's cheap, easy, and I can almost gaurantee that will make a difference in throttle response and performance. It made a huge difference in mine anyway.
