Hey - what the #*@%
Jersey Fred
Medford, NJ
Has anyone priced the 'Upper Complete Gasket Set' (E9DZ-6079-D) from FordPartsNetwork.com lately?? It went from $128 to $285 in the last six months!!
I tried to order the Fel-Pro gasket set from AutoZone and they are saying that they dont carry it anymore.
Any suggestions on where to get the plug well seals & valve cover gaskets for a reasonable price?
gdsqdcr
San Mateo, CA, USA
I just picked up a set from Kragen. It was the FelPro set and it cost me roughly 90 bucks. This was only 2-3 weeks ago. It did include the Spark Plug Well Seals.
Anthony
Jersey Fred
Medford, NJ
Just went to their website and found the Fel-Pro set for $88.79 + shipping. I really didn't feel like shelling out $285 for the gaskets!
Thanks Anthony.
ghostrider
Mt Juliet, TN
You could also get a set from Sho Nut for like $147. It's for the atx part# F3DZ-6079-C. The only thing you won't use is the head gasket. Everything else is the same. It includes all this stuff
secondary intake runner to plenum (4)
primary intake runner to plenum (2)
throttle body to plenum
IAB/ISC (2)
intake runner to head (2)
spark plug tube (6)
thermostat ring
schrader valve top
schrader valve bottom
pressure regulator top
pressure regulator bottom
snubber top
snubber bottom
LH valve cover
RH valve cover
RH thermostat housing
LH thermostat housing
EGR/exhaust manifold
intake valve seal (12)
exhaust valve seal (12)
exhaust manifold (2)
injector to head (6)
injector to rail o-ring (6)
injector to rail gasket (6)
front cam seal (2)
upper cam cover gasket
cam seal (3)
water pump tube o-ring (2)
head gasket (2)
<small>[ June 19, 2002, 03:01 PM: Message edited by: ghostrider ]</small>
fredhurderjr
www.neshospecialists.com
Autozone - Fel-Pro Valve Cover Gasket set #VS50378R (incl. plug well seals) - $71.99
Autozone - Fel-Pro Intake manifold gasket set #MS94831 (includes intake runner to head metal gaskets, all upper intake manifold gaskets exc. TB) - $45.99
Autozone - GP / Sorensen TB Gasket set - $4.99
Or, like Rob mentioned, use the ATX Upper Gasket Set from Josh at SHO Nut for the $150 range. If you need the 3.0L head gaskets, let Josh know & he'll try to match you up witih someone who bought the MTX gasket set but didn't need the head gaskets.
Go to AutoZone.com's site and look up the part for a 1991 SHO:
Home > Shopping > External Engine > Valve Cover Gasket
FELPRO RUBBER GASKET, VS50378R, $71.99
ROB L
RI
Hi,
I have a 1993 SHO w/ 3.2L Auto.
The guy at Autozone said the VS50378R part # is for the 3.0L not the 3.2L
Will the same kit fit either???
If not what part # do I need?????
Thanx,
ROB
There are a few cross referencing problems with the AutoZone data base. That Fel-Pro gasket set is good for all Gen I&II SHO's.
ROB L
RI
THANX Alot guys :) :)
I will order them today.
Anything else I will need to finish the job???
Anything else I should do while in there???
Also could a bad set of valve cover gaskets be causing smoke to come from the back of the firewall area??
ROB
DigDeez:
........and can you purchase the plug well gaskets separately?
Well, you can, but for more than the cost of the complete Fel-Pro set. Why bother?
Machspeed
Former 1991+ owner
Santa Barbara, CA
I used to work at autozone, DO NOT trust those computers when looking for sho parts, get the part number from us on shoforum first. They had push rods for my 91 for christ sake. :rolleyes:
