RichieSHO34
genoneSHO
so drain the oil, unbolt the y-pipe and drop the pan? should I get a strong magnet to roll around in the old oil to collect metal shavings?
This just happened about three hours ago. It startswhen i rev it up and then continues untill it bogs down the comes back at a higher rpmDon't do anything with the oil just yet.
Identify source of noise:
A. Eliminate accessories as the source
1. remove belts
2. If noise is gone replace belts one at a time
3. Remove belts/idler brackets and crank pulley. Remove timing covers and inspect timing components.
B. Eliminate Clutch/trans
1. does it make the noise with the clutch in or out or both
2. In neutral and in all the gears with the clutch in?
C. Eliminate drive train
1. Does the noise change while you're driving?
2. Does the car drive OK otherwise?
If you haven't at LEAST made it through part "A" you shouldn't even be thinking about a rod bearing problem.
LOUDSHO just told me they would fit but typically after you spin a bearing you need your crank machined
