MYSHO1
PiCkLe DaNcE!
OK i am about done with my cobra brake upgrade.... but the only thing i have left is the flex line to the caliper, and the flex line is to big, the metal block will not fit on the cobra caliper, what do i do HELP!
The Cobra calipers have a different banjo bolt than the Taurus, so if you didn't get any with the Cobra calipers you'll need new ones. It's an oddball thread pitch too, so nobody usually carries them -- BTDT. Even Ford had trouble looking them up, and we ended up scrounging some from a friend.crazy89 said:Wait do i need a new banjo bolt for this?
Save your time, NAPA won't have them. That Breeze place is out by Worcester someplace IIRC.crazy89 said:I am going to try napa tommrow, then ford if this does not work i will order them from that place. thanks!
