Help!
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
OK i am about done with my cobra brake upgrade.... but the only thing i have left is the flex line to the caliper, and the flex line is to big, the metal block will not fit on the cobra caliper, what do i do HELP!
I used the ss braided lines for the caliper upgrade. I assume you are using the oem ones? Is there a metal bracket or ****** that is preventing a good fit? If so you can probably grind it off. As long as the hose end and banjo bolt form a good seal at the caliper it should be fine.
Mr Anonymous
Tire Wall
I'm with Lou -- I've only seen them used with stainless lines, not the factory rubber lines, and from memory the last time I installed stainless lines they did have smaller "blocks".
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have installed 13" Cobras with stock brake lines once. You will need to file the block a bit on the brake line to get plenty of clearance so it seals well. That will get you going, but I also recommend SS lines since our cars are getting old.
- Mike
somedude_001
Western NY
I recently purchased 2 new rear rubber brake lines and they were $35 each so the braided would have been a better buy IMO.
Either way, do yourself a favor and get new washers for a proper seal at the caliper.
Mr Anonymous
Tire Wall
crazy89 said:
Wait do i need a new banjo bolt for this?
The Cobra calipers have a different banjo bolt than the Taurus, so if you didn't get any with the Cobra calipers you'll need new ones. It's an oddball thread pitch too, so nobody usually carries them -- BTDT. Even Ford had trouble looking them up, and we ended up scrounging some from a friend.
MYSHO1
PiCkLe DaNcE!
I am going to try napa tommrow, then ford if this does not work i will order them from that place. thanks!
92sho16
b00sted
Liverpool, NY
not to hijack but those who are running ss lines which one are they? for the cobra or the sho?
Mr Anonymous
Tire Wall
Save your time, NAPA won't have them. That Breeze place is out by Worcester someplace IIRC.
MYSHO1
PiCkLe DaNcE!
Just order the banjo bolts, and stainless line.... going to maine for a few days should be here when i get back!
