Help!!!!!!!!!
OSU 4 SHO
Westerville, OH
My dad and I just did the valve cover gaskets, plug well seals, cleaned the intake, installed the BBB's and hand ported intake runners and it runs rough. It also sounds like it has an exhaust leak in the rear of the engine. You can smell the exhaust fumes also. What do we do? Please help. Thanks Aaron
Mr Anonymous
Tire Wall
Any chance you broke or damaged the EGR tube running between the rear exhaust manifold and the EGR valve on the intake?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Just be very careful pulling it out - They are (as you've found) somewhat fragile. If the other is broken or breaks while you remove it, I think you can just have it welded together so that it isn't so apt to come apart again.
