Help
Ma@N
Florida
I can not get my oil filter off. I have so much blisters on my hands its not funny. Anyway the filter just screws off correct. Anyother ways to get it off. I would like to know.
Thanks.
Zpak
Es Aich Oh!
The region, Indiana
As a last resort you can drive a long screwdriver into it. It will give you leverage to twist.
Always oil the gasket. Ha
Do you have a filter wrench? You need one if you do your own oil changes
typically 2 styles- look like look like these
1720477259507
1720477277758
Zpac's screwdriver tip will work but that is an emergency, make a mess, last choice.
Irish Pride
Irish Inside
MusicCityUSA
When reinstalling, oil the gasket and only tighten it hand tight.
-Chad
shaldaya
Utah
The y make filter wrenches that go on a 3/8 wrench with extensions
Thats what I go to when I have no luck, and usually when I go to those, the filter gets crushed before it loosens
SHOnion
USA
Thanks.
damn HAHAH ran into this quite recently.Penzoil 76/14 filter wrench is what worked for me.Def double check that cause it was 1/2 pulled from my tool box and 2/2 is for a motorcycle(or vice versa LoL).Very little clearance for the screwdriver,strap wrench,or pliers if you ask me.
