Help with tires and rim wigth
1993MTXSHO
Its a Taurus...
Jersey
ok guys I know there are 8 million tire threads out there and i did do a search. I came up with this: http://www.shoforum.com/showthread.php?t=50496&highlight=stock+tire+size looked great until the top link didnt work about offset. Anyway I am getting a set of wheels with a 35mm offset, do you guys think a set of 235/50/16's will work or do you think they will rub. I have eibach springs btw, dont know if that matters much. I have a set of team dynamics wheels now, but i dont know the offset. Is there anyway to measure the offset accurately?
I have a set of 16"x7.5" wheels with the 35 mm offset and I had to do a lot of fender trimming (3.8") to get 225/55-16 tires to fit in the fenderwells. The Gen II has more clearance, but be careful with that offset that pushes the tires quite far outboard for our suspensions.
1993MTXSHO
Its a Taurus...
Jersey
ahh o well i already ordered the rims. Ill go with the 225's and hope for the best and if i get burned i get burned. I had 225 55 on these same rims i just bought but i dont know if the offset was the same or not on the old ones as the new.
jedhead
westminster,ca
I have 17X8 with 35mm offset. I have 235/45WR-17's and need to roll the rear fenders. 225 would have fit better.
Bob
1993MTXSHO
Its a Taurus...
Jersey
Bob
how close are your tires on the inside with that offset they dont run on the shock or anything? I had 225's on my old rims and they were about a 1/4 inch away from hitting the shock on the inside.
jedhead
westminster,ca
Plenty of clearance from the struts. 35mm offset pushes the wheels out if I went with 45mm offset I may have strut clearance problems.
Bob
1993MTXSHO
Its a Taurus...
Jersey
ooo ok so thats why ill have quarter panel problems? How hard is it to roll the quarters a bit. Does it crack the paint usually and can i do it myself or do i have to buy the tool to do it?
poffffd
