Help with Keyless entry system
SHO_Me_Da_$$
Salem, bOregon
I just bought a '91 SHO, but the dealer I bought it from didnt have the Code for the keyless entry pad.. is there a way I can get it?
30footSHO
In da mountains
Boise, ID
Type it in on the keypad. If your keypad does not light up when a button is pressed, then it probably does not work. Mine works, but the lock motor is burnt out. This could also be one of your problems. Another place to find the code is on top of the keyless module---it's located behind the backseat, close to the left wheelwell. The code should be on a sticker on top of the module.
