Help with Engine Size
PikeZ184
Kansas
Recently purchased a '93 Manual Transmission SHO. Can anyone tell me what engine I have, or how to identify it? The person I bought it from thought it was a 3.2L but everything I read about what was available points to 3.0L.
Also, is the crank position sensor and the water pump the same between the 3.2L and 3.0L?
frosho
WOLFMAN
Tyngsboro, MA
Manual SHOs came with 3.0's, automatics came with 3.2's. Some people swap the 3.0 for the 3.2 though. Is your coil pack level with the ground, or angled? How many accessory belts do you have?
I'm not sure about the CPS and water pump compatability.
jelloslug
Digital
Greenville, SC
No MTX cars came factory equipped with 3.2s. There are several 3.2 swapped MTX cars out there but the chances of some one owning one and not knowing it are slim. There are a number of ways to tell but pics of the engine bay would be helpful. The crank sensor is the same for both engines but the water pumps are different on the STOCK versions of the 3.0 and 3.2.
PikeZ184
Kansas
The car has two accessory belts. I am unsure on the coil packs...I am out of town right now so I will check that when I get back.
shoon
cliTaurus
Dawson Creek, BC
if there are 2 accessory belts that means it's the 3.0. The 3.2 came with one accessory belt to drive everything.
Also, the water pump is different on the 3.2 and 3.0.. but the crankshaft sensor for the 3.0 and 3.2 is the exact same part.
frosho
WOLFMAN
Tyngsboro, MA
Still could be a 3.2-swapped car with 3.0 accessories. Probably is a 3.0 though.
1993MTXSHO
Its a Taurus...
Jersey
only way to tell form the outside is to look at the side of the block, they 3.0L and 3.2L blocks looked different but its hard to tell with it in the car.
revhardSHO
Seattle, WA
92sho5spd3.2
235k miles
Ramsey,MN
Also, the water pump is different on the 3.2 and 3.0.. but the crankshaft sensor for the 3.0 and 3.2 is the exact same part.[/QUOT
Um.... I dont know, On my sho, 3.2 mtx I have two belts also, but to run a 5 spd you have to use the 3.0 accessory drive unless you want to modify the motor mounts. At least on my car.
shoon
cliTaurus
Dawson Creek, BC
the 92 SHO's only came with the 3.0 so if you have a 3.2 in there with 2 belts, someone must have swapped the motor at one time... Don;t think its the original motor.
Rockauto only lists a 3.0 for a 92 SHO... but in later years the 3.2 is an option.
Mad Celt
Fa' SHO
York, ME
Because the ATX didn't come about until 1993.
TankII
Bolton, CT
It is possible it as a 3.2 piston kit. You won't be able to tell that unless you pull the heads off.
TankII
Mad Celt
Fa' SHO
York, ME
C'mon...anyone who's has a 3.2 dropped in or had a 3.09 punched out would surely pass such info along to the next owner...it would be an enthusiast and we never shut up :)
