help with engine damper strut
mf2222
hawaii
Hi, I'm trying to replace my power steering pump.
Directions tell me to remove the engine damper strut. I am a bit lost as to what this is. Is there only one? Where is it located? Hard to get? It has to be removed before the car is lifted....???
A second question.... Are there diagrams available to look at for these things?
Thanks for any replies.
oh_SHO
Ohio
I believe there are two of them. One attached between the strut tower and the front of the engine. The second is attached to the front motor mount. I THINK they are only on MTXs.
93nighthawk
Mitchell, SD
It would help if you put year, tranny, milliage, or anything else you want to say in your sig.
If you have an MTX, oh_sho answered your question.
If you have an ATX, then there are none.
