help with alt belt tightening.
tery
Silvia survived the purge- summer car
minnesnowta
Hi, On Bob, MTX, i switched out the old alt with one I got here on the forum and now the bat light is out and it seems to be charging fine. The issue is that I feel like I have the tensioner/allen screw all the way up, and the belt isn't as tight as it should be. It's tight enough to run but it is not tight enough, I'm sure. It feel like the adjuster reached the top of it's turning range..What happens to the thing if you try to turn it even further?? Or is it possible that it just has never been turned further up than I found it and it is just really sticky/rusty/needing to be cranked on even harder to get the belt tighter???? Any help you have will relieve my worrying about it. The other thing aI thought is that maybe the pulley on the replacement has a very slightly smaller circumference?? It looks like the same diameter for sure, but are there different circumferences such that a smaller one would not let the mechanical tightening system work properly???
Soon,
T
tery
minnesnowta
any thoughts on the tenisioner issue I wrote in the original thread??
tery
minnesnowta
Thanks, I think I reached that point. I just don't understand why this alt doesn't pull the belt the same. The other one had a full turn to go and was right tight, With this one, I'm "bottomed out" I'm pretty sure...and although the belt turn the alt and seems to be charging (the bat light was on with the other one and it is off now)...but you can see a little slop/unstable movement from the belt when you rev it and watch the belt looking down in the direction of the air compressor.
tery
minnesnowta
yup, for sure ac compressor, crankshaft pulley, under the tensioner pulley, and over the alt
tery
minnesnowta
Now wait aminute....I don't think I ever loosened the bolt in the center of the tensioner....do you have to do that???
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The screw should only turn, not go up or down. Did you loosen the pulley nut before turning the tensioner? You must do that first.
tery
minnesnowta
crap, no...I forgot...I'm thinking it must be somewhat loose crap crap crap...
tery
minnesnowta
welll, hells bells, now I know what to do in the morning....!!! I hope I didn't *&$k anything up
tery
minnesnowta
So...
1.Loosen tensioner bolt
2. adjust belt tension with 5mm allen
3.tighten tensioner bolt
Good thing I;m paying more attention when I'M ACTUALLY DRIVING THE CAR....
kevinspann
Don't take my advice.
Richmond VA
So...
Yep. There is a fair amount of adjustment in the tensioner too, should be enough to take up any slack with just a smaller alt pulley, IMO. And yes, the threads on the allen bolt could be rusted as well.
tery
minnesnowta
all good now...some one say...!!!wake up old man!!!!
