I will be using a lighted 3 prong switch. I will be splicing into a ground wire, and the switch will be controlling it. (gen.3 sarc mod... tapping into the ground wire at the sarc brain in the trunk. The switch will disable the SARC mode)
So, the wire the switch is controlling is a ground wire. Is it even possible to have the light on the switch to work? Can I just run the middle prong to a power source? This is backwards to most switch hookups, no?
