HELP window is stuck down!!
edogg23
Buckley, WA
Anyone know how to get the backseat window back up. It froze up in the down position and I had my gf sit there and hold the up botton while I tried with all my strength to pull on the window and pry it up. It wont budge! What do I have to do to get it up. Do I have to take apart the whole door?
Do the other windows work? If not, check the fuse. If the fuse is okay, it may be the switch. Try both the switch on the driver's door and the switch on the rear door. If neither works, it may be a failed motor. That is a little tougher to fix. The switches just need their contacts cleaned periodically from the current arcing when the switch is released.
