hi! Im a new SHO owner and i bought a not well running car. heres the problems.. can any of you identify the symptoms and tell me whats wrong?
First of all... every now and then the car starts just fine and runs like it was born to.. 3-5 minutes... then dies. After it dies it WILL not start again for the longest time... It cranks and cranks and cranks.. but doesnt fire.
I would have never bought it except that IT does fire and get running.. so i feel it can be repaired.
EGR and sensor was replaced. it DID have error 335 or whatever...
"EGR not opening responding.." then it had the "EGR Signal to low"
Would either of these cause the car to NOT Fire?
ok.. when the car is running now there is NO CODES.. just 111
and yet it just dies.
Various tests have been performed, ranging from but not only..
Assuring signal when key is in start position (mech said it was to make sure it was getting the "Start now command"
EEC checked,
ALL fuses checked.. in car and underhood.
Fuel filter checked, fuel pressure checked,
Everything else seems fine.
IS this possibly a Cam Position Sensor?
would that allow the car to crank but not fire?
I was told the car should run even if the EGR was shot... just run poorly.
Anyways.. it spent 2 days ar MIDAS and theyre stumped..
Tomorrow it goes to FORD dealership, can anyone provide me some useful ideas or advice?
Thanks Guys.
EEC checked,
Thanks Guys.
