help. no start. need fixed asap
zblackbeast
SHOtarded
Omaha, NE
my 93 died at work today.. It gets power but when I turn the key there is NOTHING. no clicks, nothing. I think it might be the clutc interlock switch..
Vnuk1
Mr. Mayhem
Minnesota
Assuming you checked all your connections for loose and corroded wires?
zblackbeast
SHOtarded
Omaha, NE
I'm waiting for AAA to come but untill them I can't get under the front because the guy driving it drove to far in the parking sopt and its down hill.. lol but battery wise everythings tight and everthing else seems to be getting power other than the starter.
1995SHO9
FLEES ARE COMIN
Carlisle PA
X2 on what Vnuk said. Try sticking a screwdriver or somthing across the Starter Slolidnoid. If you don't have any tools, try using the lug nut wrench.
SHO.fast
Wants Boost
Littleton, CO
x3 happened to me
i replaced the starter relay/solenoid and it started right up after a good jump
zblackbeast
SHOtarded
Omaha, NE
aight. i got it home. ill get some pix up of the tow soon!! Ill see if i cant get it fixed tonight!
zblackbeast
SHOtarded
Omaha, NE
Same thing.. Nothing. I replaced the solenoid on the starter and nothing.. Whats next? I hear a click when i turn the key to run by the air box.. IDK exactly what it is, but it clicks...
zblackbeast
SHOtarded
Omaha, NE
lol sorry grammer bad at midnight, i hear a clicking by the air box when the key in the ignition is turned to start!
SHO.fast
Wants Boost
Littleton, CO
exatcly what happened to me when i replaced the starter solenoid/relay
i tried starting it and it clicked by the air box (which is where my relay is at) i gave it a good jump and it started up after about 5 minutes
also check the solenoid again to make sure you didnt break any of the terminals that connect to it
zblackbeast
SHOtarded
Omaha, NE
Just did that. nothin.. should i unplug the battery for a while or let it sit connect for a while?
SHO.fast
Wants Boost
Littleton, CO
un plug the battery for about 3 minutes then hook it back up , then jump the car,
did you check the terminals on the solenoid?
that was what worked for me
zblackbeast
SHOtarded
Omaha, NE
The solenoid is BRAND new. i just put it in last night.. but ill go check again.. ill bring my computer out with me! :D
SHO.fast
Wants Boost
Littleton, CO
cause i replaced my solenoid and in the mean time i broke the fuel pump Terminal going to the solenoid
i was wondering why it was cranking but no start, then i realized i couldn't here my fuel pump check out the solenoid and found my problem. and let the car sit for while when it is being charged , don't just start it up right away let that battery juice up a bit for about 5 to ten minutes then give it a shot
zblackbeast
SHOtarded
Omaha, NE
Terminals are fine. nice and tight. i got fuel cause the pump is kicking on.. just no cranking still. battery is unplugged. check back in like 10 min!! ;)
SHO.fast
Wants Boost
Littleton, CO
well if your terminals are good and after you charge it for awhile if it doesnt start then im stumped because the problem your having is exactly like the one your dealing with , it would click at first when i first installed it it would click, then after i charged the battery for about ten minutes it stopped clicking, but that is when i found out i had broke a terminal , fixed the terminal and it started right up
zblackbeast
SHOtarded
Omaha, NE
Bridged the terminals and it sparked but did nothing... Im pretty sure its the starter now! :(
