help no juice to the fuel pump
sccasho
kenova, wv
i am getting no electricity to the fuel pump in my 92 mtx i have checked the reset switch some blow jo mechanic was trying to tell me it was the control module located on top of the radiator any help would be greatly appreciated
Mr Anonymous
Tire Wall
sccasho:
does that module go bad alot
Sometimes. That module is called the CCRM (for Constant Control Relay Module). They run $80-$120 depending on where you get it, or cheaper used.
It's been know to fail over time for quite a few owners. Any part over 10yrs old is suspect on a car.
sccasho
kenova, wv
hope i am not of burden with all these rookie questions but what years can i use with the 92 or is it only 92's
HopefulSHO
Bellevue, NE
It's probably pretty interchangable. I swapped that same module over from a buddys '95 to see if it was the problem (it wasnt) on my car. My SHO is a '94 BTW, part #'s were the same, probably will be for you too.
sccasho
kenova, wv
yeah but mine is a 92 would they have used the same parts for the later gen 2's?
Mr Anonymous
Tire Wall
sccasho:
All MTX's share the same CCRM '89-'95, and the Gen II ATX's share the same (but different from the MTX) CCRM. Some junkyards may refer to it as an EEC relay module.
sccasho
kenova, wv
thanks for the help ill try and find one tomorrow most likely i wont find one in my general area
