Help me.
marbs
Roy/Ogden, Utah
I replaced my Timing belt, and Water pump a while ago. I can STILL smell burning anti freeze a little and every once in a whileI have to fill my overflow. Any ideas what this could be? Also replaced upper and lower radiator hooses. :cool:
SHOtimer
#2910
Santa Clarita, Ca
Well, the upper rad hose wouldn't leak any anti-freeze onto the exhaust. Only the water pump or the lower hose will do that. Did you replace the O-rings behind the water pump? If not, I would say that is probably your problem. But, the only way to tell is to take the front of the motor apart and inspect where the coolant is coming from.
Doug
Redline
Fire It Up
Sandpoint
Mine was dripping onto the cats from a heater core hose by the firewall. Might want to check those.
