help me please going crazy 91 sho
john p
I own a 91 SHO which refuses to start after I replaced the clutch .
The work of replacing the parts was uneventful for the most part, the one thing that should be mentioned is that when the trans was being lowered the shift fork caught on a wiring loom, nothing drastic I thought at the time but apparently I was wrong? All connectors have been checked and no problems found, but I'll continue on anyway.
After the car was all buttoned back up I tried to start the car and it cranks just fine. My current symptoms are: No CE light, no fuel pump prime, cooling fan stays on all the time when key turned to run or start.
Thus far I have checked KAPR and grounds to both the EEC and IRCM, both voltages and resistance are good. I have replaced the main wiring harness from the EEC to the IRCM, replaced the EEC with a known working unit, replaced the IRCM with a known working unit and many many other voltage checks. There are two topics on my forum of all the measurements and tests that I have done, none of which have rendered me any positive resuilts.
I am posting here today because I wanted to get some fresh thoughts on the topic. Things that I would like your thoughts on are detailed below. Keep in mind I am electrically challenged; I'd rather change 20 clutches and rebuild 50 transmissions over having 1 electrical issue any day of the year.
EEC (no CE light) - This from what I'm told is often caused by no power or no ground or LPM issues. I don't have an LPM installed at the moment and power and ground have both been verified. To my knowledge pin 20 is case ground, pins 40 & 60 are power grounds. Pin 46 is the ground (or signal return) for the sensors attached. Is there another ground that I could be missing?
The cooling fan running constantly when the key is turned to run or start I think is tied into the EEC issue. My thoughts are that when the EEC issue is cleared up this "symptom" will resolve itself as well. Thoughts on this?
Fuel pump no priming - The first thing I verified in this was that the inertia switch was not tripped. I manually tripped it and reset it just for good measure. Continuity from the EEC to IRCM was verified, from the IRCM to the inertia switch was also verified. There is no voltage from the EEC to the IRCM however.
From what I understand, the EEC will lower the voltage on pin 22 for several seconds in order for the fuel pump relay to energize on the IRCM. This is not happening. Questions are why? And how to correct this?
The fuel pump will energize by jumping the test connector. I can also manually power the fuel pump at the computer and the IRCM to make it turn on. Another question, is this just another symptom of an EEC problem that will resolve itself once the EEC issue (no CE light) is resolved. I'm leaning toward yes.
I know I have left many details out, but I have been going around and around with this since early July so my thoughts are jumbled with things I simply don't understand.
If you have any suggestions on something to check or thoughts on the matter in general (aside from parting the car, this is not an option in this case...too much $$ involved in this car) I'd greatly appreciate reading them. I have at my disposal a breakout box, 91 schematics, shop manual and EVTM, 92 and up CD roms.
Sign me.... "Desperate in Michigan"
Off Road SHO
Moderator
Hmmm... cooling fans running all the time eh? Aren't the fans normally powered up by the CCRM or (ICM) on the radiator brace? Something has sent the trigger signal (usually a ground from the PCM) to the CCRM, causing the fan relay to activate. I would be looking for a pinched wire or wire bundle.
Tom
john p
ok that makes sences what about the fuel pump not geting power thats the big issue
john p
i tighted the pcm still doing the samething where would the ground be to the pcm
Off Road SHO
Moderator
It too is fed by the CCRM on the radiator support. I'd start looking real close at that bundle that got hung up.
Tom
No connection or loose pcm connection would cause these symptoms.
But a trigger wire grounded out or smashed against a ground wire might.
Tom
cooling fans running all the time when key is turned on is a symptom of bad connection at the pcm or no ground to the pcm. I would start there.
CCRM have relays for both the fuel pump and the cooling fans. Since it ran fine before you did the clutch and not so much now, most likely is you fragged up some wiring that you can't see and will be chasing your butt for a bit. Good luck. The wiring on these cars is already getting old and brittle. A lot of us have been chasing more electrical gremlins last few years. I wonder if Ford garages or maybe auto electrical specialty shops have diagnostic equip that could trace this down much more quickly?
john p
okay guys I'm having a little trouble determine the PCM from the ccrm is the CCRM the black box mounted right in front of the radiator with the letter M on it or is that the pcm and if that is the CCrm where is the PCM located is a right next to it that little black box
john p
Ok what I have figured out if the little black box with the M on it is the CCRM
It is getting power there is 16 - 17 volts going to the trip sensor in the trunk for the fuel pump In N Out I'm getting the same reading so I know the trip sensors good so that leaves me with a bad fuel pump or there is some kind of an issue with ground somewhere because my fan is still on when I turn the key on went through found all the loose ground and tightened all the grounds up and still doing it
I would poke around the board here and the interwebs to see how to pinpoint this stuff and run tests. There are lots of regular taurus and sho posts on the Taurus car club of America site and other places. Google can help with this stuff. I am wondering if you ran (jumper inline) a power wire to the fuel pump assembly if that would confirm whether the pump is good or not.
You need to get the "cooling fans run all the time with the key on" problem solved before you will learn anything jacking around with the fuel pump. The pcm is not working right - you either have a bad connection there, or a bad ground on the pcm circuit, or you fried the pcm. The fuel pump will not work right until the pcm works right, so you are chasing your tail right now.
itwonder
VA
With the car running, the cooling fan will run all the time if the A/C is on; up until the vehicle reaches 40 mph. IIRC from messing with my fan a while back, it is possible to get the CCRM in a state where the fans will come on when the key is turned ON. I can't remember exactly what it took to get it in that state or back out again; it may have been as simple as turning the A/C off then back on. I'm not sure what to suggest to do about it if the car won't start. But I would ignore that for now.
Something is wrong with your readings. If the car is not running, there is no way you can have 16-17 volts. That would be too high even with the engine running! Keep in mind that whenever you are tracing voltage through components that have nechanical contacts, like relays, switches, and circuit breakers, it is possible to measure normal voltage, but corrosion or wear on the contacts may cause them to not be able to pass enough current to operate the device that is the load.
the cooling fans should not run with the key on (engine off) even with the a/c on. If the cooling fan runs when you first turn the key to "on" then you have the pcm wiring issues I described above. BTDT.
john p
the pcm located behind the glove compartment right know the ccrm is located next to the radiator
john p
Does anyone know if there such thing as a passlocke or passlock2 built on the 91 sho mtx
If you're asking about anti-theft then no. There is an alarm but no ignition disabling. PATS I think was first brought to the Taurus on the GenIII 96+
john p
OK thanks I have gone through everything check all the wires all the grounds everything looks fine to me bad PCM I think so I'ma go ahead and buy new PCM and a new CCRM and see if that takes care of these issues unless anyone else give me another pointer on how to test the PCM without a breakout box
