90MTXSHO
Prez for Life
Alright - some time ago, my car sprung a leak. It really smells of coolant, both with the heater on and off, vents open or closed. I can open the window and get some relief, but I don't like whiffing coolant whenever I drive.
Here's what I know. The leak is coming from the back of the engine, dripping on the back cat, and sometimes vaporizing, thus the smell, or dripping on the ground. The temperature of the engine runs hot until I put more coolant in...then it's stable. There are no odd noises, but the car does feel a little hesitant at first, until around 4k when it goes back to normal and flies. I was just under the car and noticed that there's a little wetness near the middle axle coming from the tranny, but the two I believe heater hoses (near the top of the engine, just behind the intake?) are dry, and the water pump feels dry (when I run my hand under the pully against the block. The car hasn't had symptoms of a bad CPS, which leads me to think - after all this time of not killing - it isn't the water pump. Finally, the head gasket's in tact (just to throw that out), no leaking from it.
What the **** am I missing here? And more importantly...how much is this going to cost me to fix?! Thanks!
