HELP. ideas?
Kalamazoo, Michigan
there's a very noticeable rubbing noise definitely coming from the front right tire area only when i turn the steering wheel. It makes the noise whether I turn right or left. I've replaced the outer tie rods on the front, had wheels balanced, and did a front end alignment. Wheel bearings also seemed good. Another steering issue of my 92 mtx is that there is a little play in the steering when you turn right. screwed up gearbox? anyone have these same issues?
notbange
Love fiST
Sale Creek TN,formerly MA
Frozen strut mount bearing? Makes a grinding or groaning when the wheel is turned. A dried out tie rod or balljoint would make a squealing noise. But you've replaced the outer tierod already.
