help finding tss plug???
ThatShoGuy
michigan
well i think i figured out my trans issue ther is no plug ,pluged into the tss sensor... were does this plug come from i cant seem to find it..
i did just put this motor in so i guess it could be anywhere???:oogle:
Mr Anonymous
Tire Wall
It's on the same harness as the downstream O2's, P/S and VAPS connectors. It should loop under the tranny dipstick tube and across the tranny to the TSS.
ThatShoGuy
michigan
well i found my plug it was melted to the exhaust manifold.. no damage really....
trans shifts great now....
now i got on the wire loom
2 o2s
1 gray plug that go's to the rack
1 black plug that go's to the tss
now there is one more black plug on that loom looks just like the one on the rack.. were does that last black plug go??
:thankyou::thankyou: again
venom
Rowboat Design
Toledo, OH
That goes on the rack as well
2 o2s
The two pin flat rectangular plugs both go onto the rack, one is the pressure switch so the PCM knows when you are demanding power steering so it can increase the idle to keep the car running, and the other is for the variable assist that our cars have. The two are just a few inches apart.
ThatShoGuy
michigan
wow i cant find the one that takes the black plug guess im gonna have to look harder 2morrow
Mr Anonymous
Tire Wall
Look on the rack, there is a silver cube about 1"x1", and the connector is pointing at the ground.
