HELP !! COOLANT LEAK
anthony
new york
I have coolant leaking onto front cat.
Its a small leak but can't find where its coming from ; i had it on a lift and didn't see any hoses leaking ,the water pump looks dry ,it looks like it coming from behind the timing covers .
Any help would be great . THANKS....
3xSHOloser
MO
Sounds like the bearing in the waterpump has gone bad, there's a weep hole on the waterpump and it will drip water out of it when the bearing goes, but this usually happens when the car is running and coolant is hot.
nothingtoseehere
The area yuo describe for where it is dripping from and where it is dripping to is precisely the waterpump. Sorry to sya bud, but you need to replace it.
