Help!!! ASAP!!
tizzem
tac
i don't think it's overheating. When I drive it, the temp gauge stays right above the blue , but when I park it and turn the car off, the gauge goes about a quarter of the way full.
trainguy1989
SHOtarted
Wichita, Ks
That's normal. The gauges when not energized will move to there resting position.
kevinspann
Don't take my advice.
Richmond VA
Alright, so you have a coolant leak, and a power steering leak (and probably oil leaks too).
Find your coolant leak, repair it, then drain it, maybe flush the radiator out if you can too. Refill and if it doesn't leak consider that done.
Power steering leaks shouldn't be hard to fix, there is one large line from the reservoir to the pump, a high pressure line from the pump to the rack, then a line from the rack to the power steering cooler at the DS front of the engine bay, then a return line from the cooler to the reservoir. Fairly simple find and repair.
tizzem
tac
wow... now i wont start... its fine untill i press the clutch in and turn the key. The the whole car just acts like it has a dead battery.. so I rep-position the connections at the battery posts and it's fine till i try starting it again.. wow.
tizzem
tac
wow
I drove it around for a while today, nothing was smoking or leaking. Upon checking the car out again, I realized that the power steering fluid was completely empty. That's the problem and where the leak is. No coolant leak, no oil leak, just power steering fluid. WOW. Thank god. Now it's time to install my zex kit and YES I'm keeping the car.
93SHO24V
MN
Next post will go something like- Hey everytime I start my car it goes clank clank clank clank. The idle is really rough and I keep hearing popping noises coming from the oil pan.
