Ok I narrowed it down to these last 5 options to comeplete my triple gauge pod setup(2 remaining to buy):
-Fuel Pressure 0-100PSI - 2 1/16"
-Air Temp 0-200Fdegrees - 2 1/16"
-Oil Temp 100F-300F degrees - 2 1/16"
-Volt meter 8V-18V - 2 1/16"
-Oil pressure 0-100PSI - 2 5/8"
My first choice I bought was a 2 1/16" water temp w/sender, now because I waited so long I can no longer find my 2nd choice of a 0PSI-100PSI oil pressure in 2 1/16" only found it in 2 5/8" size would I be able to trim the gauge pod to make these fit or do I have no choice?
Basically I need other's opinion on what to buy for my last 2 gauges taking the above into thought?
