Help Again !
SHO 508
Brockton
I checked the fuses, new battery, but the battery light flashes, and gets drained. then i have no directionals. anyone else have same problem?
Fuse-checked
New ALT- checked
Battery- checked
All the wirings-checked
I did the computer thing that says 111 * system pass* then the 2nd time it says 112 which there is something wrong that drained my battery....any ideas ?? I need to go work tomorrow.
Turn signal/wiper/wiper washer/high beam/low beam/flash to pass switch.
SHO 508
Brockton
Ok , all done ...it works now however i had to change battery three times already and its killin me ... what it is ?? it is brand new ALT ....damn
Mr Anonymous
Tire Wall
Sounds like a bad brand new alternator. It happens.
SHO 508
Brockton
Ok , I changed the battery and alt today n ran for an hour ( when it gets hot ) it wont start so it must be something drained the battery or fried the alt ?
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Look for hot wires , you MUST have a serious shortage somewhere.
Car running you should read 14.4 V on the batt. and 12V stopped.
if you dont get the 14.4 the alternator is not charging and you used all the batterie's juice.
