Help! 93' chugs & falls on face
RacingNotPacing
Lawrence, KS
well this has been occuring for quite some time now, but if i rev the motor in neutral everything sounds fine,, but if i start to take off it'll chug pretty hard untill about 15 -20mph, then if your just driving & hit the gas it wants to fall on its face.
Could this be the fuel pump or fuel pressure regulator?
thanks in adavnce!:thumb:
BangSHO
Lincoln, Ne
have you checked your plugs lately, mine used to chug on acceleration sometimes when i had oil in my plugwells, but since i replaced the seals, plugs and wires i havent had any chugging problems. im not an expert by any means but its just a thought
RacingNotPacing
Lawrence, KS
I'll look into that, but the cosistancy at which it occures makes me think its somthing eles,, but I'll deffinetly check.
Thanks
bertha66
central oregon
Have you run the codes on it? I agree with BangSHO, Plug wires and plugs are a good place to look also. If you have a inductive timing light, hook the lead to each of the plug wires as the engine is idling to see if they are all firing at low RPMs.
SHO#7
Cincinnati
Start with the codes. Also, you may want to clean the MAF. Or try to run it without it. If it runs better with it disconnected, that would be a good place to start.
mike
mylaw
The Sho Time
Ottawa
Also have a look at your cat and make sureit is not plugged up...
RacingNotPacing
Lawrence, KS
ok so i got a chance to drive the SHO again this weekend, all the original problems still exist, but another thing i noticed was from take off that it will fall on its face at 1/4 throtle just as it would at full, so it takes a while to get some rpms built up. but man just as i was about to give up on her I got it to rev up & kick the secondarys open & for a brief moment she was the same hot rod that i remember.
Testing the codes-
I don't belive the check engine light is on, would there be any codes to read?
Checking on the cats-
how is this accomplished exactly? & if this would be the problem, could it run with the cats removed? or would there be to great of a loss in backpressure.
Fuel pressure-
a few months ago we check for fuel pressure with a old crappy gauge & if i remember correct it was reeding atleast 60psi. is that too low?
bertha66
central oregon
To check the Cats, take it to a good muffer shop and see if they would check teh flow. Have you checked the plugs and wires?
RacingNotPacing
Lawrence, KS
not really,, but i do remember seeing oil on top of the valve cover, & it seemed like it was comming from the plug wells. so I'm sure it all needs replaced. I know for sure that it needs the 60K done, but i only wanted to tear it apart once, so i was saving the plugs & wires for then,, my plan is to make sure it not fuel delivery of somthing out side of the motor, then if it comes down to it I'll just do the 60K.
what all would i be waisting if i replaced the plugs & wires now,, then ended up doing the 60K say 6 months from now?
bertha66
central oregon
Should not be waisting enything, at worst my have to replace plugs. I have been gettine 50k+ out of my cheep wires.
RacingNotPacing
Lawrence, KS
are these two sets going to be reusable?
69.99- FEL-PRO valve cover gasket & plug well seal set
32.99- OEM intake manifold gasket set
RacingNotPacing
Lawrence, KS
Ok so i unplugged the MAF sensor & it runs perfect! I'm just going to swap out the sensor & see how that works out!
Thanks guys!:thumb:
poffffd
