Help, 3.0 heads on a 3.2?????
rick-ng
Rickybobby
Dallas
I heard someone say to save my 3.0 heads to put on a 3.2
Is this something that could be done????
Please help me on this one cause I would think that the 3.0 heads would have a smaller "dome"
thanks in advance
-Rick
PS I have a 3.2 sho with a bad headgasket and a good 3.0 motor sitting in the garage
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
olny do it if your making it a mtx.. if not the bolts wouldnt line up for brackets. the 3.0 cams have a better intake duration i think its .020 difference.
SuperHO
Mental Patient
St. Joe, MI
it's a higher lift...I believe duration is the same....
3.0 intake lift = .330
3.2 intake lift = .315
Exhaust cam is the same.
SHOtimer
#2910
Santa Clarita, Ca
If you putting 3.0 heads on an ATX you can swap the rear heads, however the front 3.2 head is specific to the ATX accessory setup......so you can't swap a 3.0 head onto a 3.2 mated to an ATX. Hope that makes sense.
Doug
