Heater Problem
NBSHO
When I have the heater on my idle is rough. As soon as I turn the eatc off the idle evens out. Is it something to do with the air conditioning compressor? It's mostly when the eatc is at the defrost setting?
Ishodu
It sounds like it could be the AC clutch cycling on and off. Does it go away with it on vent?
betterman
canada
Have you disconnected your battery lately? If you have you probably need to reset yuor idle. The procedure to do it is in a sticky on here somewhere.
