Heater core...really quick question.
SHOstuff
Houston,TX.
When the heater core leaks or is bad, I know that it steams the window but where does the water leak out? Some cars leak out on passenger floor so where does the sho leak at?
it might not even leak inside the car, because the housing has a drain to take condensate from the a/c evaporator and drain it outside - so it might leak on the ground.
TimboSHO
Intermediate
Wyoming, MI
I've had it leak on the driver's floor before as well. I would bypass if you are worried about it leaking before you ruin the carpet and padding.
