headliner removal
JSIL1
Mainlining
Mile High and Gaspin
Do I just need to pull off the plastic pieces off at the top of the seat belt posts (B pillars??) or are there screws as well?
P.S. Oh yeah, what is the bet way to mount to the roof? (I am putting a cust enclosure (MDF or fiberglass) not sure yet, and didn't think I could just go driving screws.
thanks
Headlining, Roof
Removal
NOTE: The removal and installation procedures for roof trim panel generally apply to all models. If one or more of the steps do not apply, proceed to the next step.
Remove LH and RH inside visor retaining screws, disconnect electrical connectors (lighted vanity) and remove inside visor. Remove visor arm clip retaining screws and remove visor arm clip.
Remove courtesy lamp/map lamp as described in Section 17-02 .
Remove assist handles/coat hooks as described.
Remove weatherstrips at door openings above beltline. Remove moulding around roof panel if equipped.
Remove windshield side garnish moulding as described.
Remove center body pillar inside upper finish panel as described.
Remove LH and RH rear corner inner upper finish panel as described.
Remove LH and RH quarter trim panels as described.
Remove pushpins and roof trim panel.
