wuzzzer
MN Moderator
To borrow a line from DJ Kool..."Some of y'all might know this, some of y'all don't..."
To continue the saga of my HID light installation:
Wednesday morning it finally warmed up enough to take out the passenger side HID bulb/ballast to send it back for warranty replacement. I decided to put in a factory bulb at the time so that I could get some side-by-side pics of the HID/stock bulbs.
Guess what? The factory bulb doesn't work now either! It does work if I put the high beams on or if I use the 'flash to pass' function.
Basically I believe it means that the low beam power connector somewhere along the line of the wiring is bad. squint
Anyone have any advice of what to look for to fix it??
frown
frown
