headlight harness from suvlights.com is in
speedysprocket
sho runner
USA
Works great, not dark yet, so its hard to tell but I installed new xtravision bulbs and nearly brand new lenses to go along with it. Install was pretty straight forward. I mounted the two relays just behind the battery and ran the length of the harness just above the radiator.
As I read in another thread, my lights out bulb is now illuminated AND my left blinker light on the dash isnt illuminating, although the blinker lights are working fine. I am hoping these are related and some folks were saying you can remove the lights out module. Where is this located? Anyone noticed the blinker "dash light" issue with this upgrade?
thx
K-Dawg
Treasure Coast, FL
I just snipped a wire above the glovebox to get rid of the Lamp Out. Should still work for the rest of the lamps. Do a search.
Don't know how the harness would affect the dash signal indicator.
speedysprocket
sho runner
USA
I donno, but when I swapped it back to stock again just to test, the blinker light worked fine. Weird. Anyway, I'll follow the posts below and snip the sense wire, should take care of it. Deal with the blinker issue later on. The car is in pieces right now I have a magnaflow y-pipe, new fog lights and new rod bearings to install. Old ones are showing a little copper, but not bad for 162,000 miles.
