Heading to the 1/4 mile tonight
hawkeye18
Sorta cares
Norfolk, VA
You're supercharged?
Make sure you bring a few spare CV axles. Brian (AREA91) can tell you all about what happens when you launch on sticky tires with a lot of power...
IF you launch without snapping an axle, and IF you don't smoke the tires (do you have spring blocks for the rear?) I think 13s certainly aren't a problem, and if you get a good 60', 12s aren't out of the question.
Michelle
Wisconsin
I don't have a lot of power. Plus, girl driver.
And I come prepared. Or I guess, leave the house prepared.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
What is your susp setup/tires/WHP, and how many passes have you made?
Let me know that info and elev of track, and I will guess within 2/10ths.
TT
BlackonBlack89
burlington county,NJ
It's not that bad. Stop blowing it out of porpition. I know threw expirence that u can drag race with out breaking axle every run. Even 2.5 hours from home or 4hrs. 12's are out of the question. 6 psi is just not enough. (votech)
Wats was the time I say 13.7 at 104. Hope the problem is minor.
Michelle
Wisconsin
I'll go back before the end of the season. I sure miss revving it way up.
Toolman
Boost it!
You can not start a prediction thread and then not tell us if any were right.
Since it seems you do not know or do not want us to know your HP level, and since I still do not know your susp/tire setup, my guess will be more of a shot in the dark. But, seeing as someone said you are low boost, I am going to guess 14.4 @ 103, with a 2.56 60'
Michelle
Wisconsin
I can do whatever I want! Ha! :evilgrin:
I'm running Konis/Intrax. Still have my NT01s from Autobahn on the car, but they are a few years old and many heat cycles on them. I haven't had the car on the dyno since the supercharger was added. It had 225 at the wheels last year.
No real times to report. Didn't make a clean, full out pass.
