Head Swapping questions.
intimdatr
Got Cams?
Jefferson City, Missouri
Seeing as i will likey be buying SHO Amo's heads :nut: (I blame it on boat! ****!) and im starting to build a list of what all i need to get and do.
Should the head bolts be replaced when you are swapping heads?
Im going to get a new set of head gaskets from rock auto, anything else i should be getting? He said it has new valve stem seals, any thing else i should do while they're apart? Any other advice would be greatly praised.
jayro
Auburn, In
I reused my head bolts. It is my understanding that they are not torque to yeild bolts (like the v8's), though I am sure some people would say replace them. If the heads have new seals then I think they would be good to go. Unless you are buying them with cams already installed, you will want to do a valve lash.
If you are installing cams be EXTREMELY careful when torquing down the caps. Have a good torque wrench and I used the lowest torque spec inthe given range.
zach44102
BIG TURBO
Georgia
This^^^ Unless you want to buy stock in Helicoil.
