intimdatr
Got Cams?
Seeing as i will likey be buying SHO Amo's heads
(I blame it on boat! ****!) and im starting to build a list of what all i need to get and do.
Should the head bolts be replaced when you are swapping heads?
Im going to get a new set of head gaskets from rock auto, anything else i should be getting? He said it has new valve stem seals, any thing else i should do while they're apart? Any other advice would be greatly praised.
(I blame it on boat! ****!) and im starting to build a list of what all i need to get and do.Should the head bolts be replaced when you are swapping heads?
