hbrace install
94mtx
san diego
well i jacked up my sho to install the rear hbrace, but i dont have the correct size socket!! i only go up to 19mm. does any one know the correct size of the bolts on rear control arms inboard side?? thanks
jon
25.4 mm to the inch. Measure it to the nearest fraction of an inch, convert to a decimal and then devide by 25.4.
<small>[ April 20, 2003, 09:06 PM: Message edited by: SHOZ123 ]</small>
BlackOnBlackATX
Dutchess County, NY
the inside nuts used a 19mm if i recall, and the outside bolt heads needed a 21mm. i couldnt turn them though so i hammered em out with the other end of my craftsman ratchet when i took the nuts off :D
SilverSHO
cartersville
I used a 13/16" socket (and a few choice words, when I bounced the heel of my hand off a sharp corner :eek: ) to install mine.
