Xtreme.NY.SHO
Okay i know i am supposed to search first and i did for a bout 10 min and found an answer to part of my question but i dont have time to search more...i have had hard starts sometimes but on the second try it would start...then every once in a while the CEL would come on for about 5 seconds and then go off. Then i just tried starting it after leaving it in my driveway for like 10min and it went tu start n then it died...i kept cranking and it sounded horrible like it really wanted to start but couldnt. then it finally strted ran like crap for a few seconds then idled fine. now the CEL light is on and the tach nor the speedo are working. How do you check the codes with a paper clip? and does anyone have any ideas about the starting?
159- (O,R) MAF Sensor is/was out of range - MAF
i thnk these were the stored ones-
212 - (M) Ignition TACH signal was erratic(module/wiring) or SPOUT circuit fault - Ignition Systems
214 - (M) Error in Cylinder ID (CID) Circuit or signal - ignition systems
556 - (O,M) Fuel Pump relay primary circuit fault - power/fuel pump circuits
i have no idea what any of these mean
