Would an improperly installed driver side halfshaft make a slight grinding noise upon initial takeoff (0-5 MPH)?
It sounds as if the bearings inside the boot are worn but the boot is not torn. My old 89 had a torn boot and I knew the bearings were making the same noise since they were obviously exposed to dirt, exc...but on my 92 the boots are intact so I'm assuming the bearings are OK. Should I replace my halfshaft anyways to get rid of that grinding upon takeoff? Would the bearings become worn even with a good boot?
Much thanks
~Alex
<small>[ June 10, 2003, 10:23 AM: Message edited by: Blue-By-U ]</small>
Much thanks
~Alex
