halfshaft boot came loose
SHOman247
michigan
the inner boot on my drivers side halfshaft came loose. So is there anyway to get the clamp off the boot? and can i just replace the boot and re-grease the u-joint and reinstall the boot and clamp?
SHOtimer
#2910
Santa Clarita, Ca
You can try to get the old clamp off, and put a new one while it is still on the car, but that would be a bit 'rickety'. The only way to replace the inner boot is to pull the axles and remove the outer CV joint and then remove the inner boot. A pain if you ask me, or you can buy a referbished joint.
Doug
rangerj
Brunswick, Ohio
If the boot pulled loose from the inner joint you need to investigate why this happened. The band that holds the boot in place has most likely failed. It can be replaced. If the boot is in good condition then get a new band. The ends of the band can be seperated, wrapped around the boot, and put back together.
Then there is a special tool for "crimping" the band to pull it tight around the boot. (If there is an indication of a loss of grease in the joint the axel should be removed so that the joint can be cleaned and repacked with grease.)
This can be done with the axel in place, but the room for doing this is minimal at best. If the boot is split or cracked it has to be replaced. The axel has to be removed to do this. Then the joint has to be removed so that the boot can be removed after the small clampping band is removed. A boot kit will have the new boot, two new bands, a new "cir-clip, and C/V joint grease.
The inner joint is a "yoke" type joint with three rollers mounted on needle bearings. Do not take these apart and risk losing one of the needle bearings (MANY). Clean out the joint and repack it with grease (C/V joint grease). rangerj
91 Plus
Well-Known Member
Monroe,Michigan
That means you better not get beat tonight by that maurader..Gonna have to wait a little longer!hahaha
