Half shaft replacement
kevinspann
Don't take my advice.
Richmond VA
Not really, It should be about the same for the driver's side, for both cars. Have a pan under the trans to catch all the fluid that dumps out.
jmpSHO2nd
Massachusetts
It's a pretty easy job just make sure you torque the axel nut down to factory specs to avoid premature failure of the wheel bearing. Good luck.
Batman007
Caped Crusader
Gotham City
book says 180-200 ft/lbs on hub nut (chiltons)
axel came off with no problem, did not need the special puller tool chilton had me order ($15 on Ebay). A PRYBAR DID THE TRICK, Just waiting on the rebuilt axel I ordered from RCM automotive.
